Go back
Using Automation to Avoid the VTP Bomb
by Phillip Gervasi Apr 6, 2024
Early in my career I laughed along with engineers making jokes about the dreaded VTP bomb, but I always thought the disaster stories were more of an exaggeration than reality. Surely VTP hadn’t destroyed networks as much as they suggested? There’s something about the simplicity of the VLAN Trunking Protocol that seems to make it dangerous in the hands of a careless engineer. And, unfortunately, I’ve been that careless engineer.
The VLAN Trunking Protocol, or VTP, is a technology used to make configuring VLANs faster and easier. Dynamic VLAN propagation ensures that all the switches within the entire VTP domain have consistent VLAN configurations, and it also means that adding new switches is simpler because they dynamically inherit VLAN information once connected.
VTP is normally found in the access layer more than in other parts of a network. Especially in large organizations, access switches are moved, swapped, added and re-added relatively often. Sometimes it’s to replace a failed closet switch, and sometimes it’s to upgrade an aggregation switch to something with more ports or greater bandwidth. In a large network with many VLANs, this makes VTP a compelling technology for making switch deployment more efficient.
However, when not handled carefully, VTP can do tremendous damage.
Using VTP requires a strong knowledge of a network, including which switches are acting as VTP servers, and on which server mode — whether transparent mode or client mode, and so on. Especially when introducing new switches into a VTP domain, it’s critical to have this type of network awareness in order to avoid a VTP incident.
Related
